Hi
How can i create a throttle / slider effect?
I play a game called Digital Combat Simulator for which i want to create a slider using the Axis controls.
However, by default as soon as you move the axis of a joystic it snaps to the center of the axis, i want to use the joystick axis on my XBOX one controller to act as a slider when i push it.
can this be done and if so how do i setup a mapping using reWASD
thanks
thanks
