How to add modifier function to Xbox Elite 2 controller?
Yep, full license and everything. I'd be happy to copy precise X and Y coordinates for the response curve, but no matter what I do I can't make it work.
For some reason, the new curve is not saved there. We have a similar bug confirmed for 6.1.0 version that will be fixed in the upcoming release, maybe that is why you can't save the correct curve.
I have created a config for you — this one works from my side. Please download it, double-click to import and check. Hope it will help!
That finally worked! That's so much. I would probably suggest making the fact that you can change the max value in the response clearer. As it doesn't seem obvious from any documentation I read.
