I was looking at the back button kits that extremerate sells for duel shock 4 controllers and they claim that they let you remap the TouchPad button to the back buttons. So I was wondering if anyone tried using (or knows if it is possible) to use the rewasd 4 button TouchPad set-up to make all 4 back buttons on the controller programmable to unque keys? I am assuming that you only can map the 1 TouchPad click button to the back keys but I figured I would ask and see if anyone has given this a try.
Extreme Rate Dawn Programable re-map kit questions
Hello. Unfortunately, reWASD cannot recognize these paddles, but you can try this method to remap them in reWASD.
