Hello, I have been using rewasd for the last year and my experience so far has been wonderful. I used the software with an Xbox One controller and the Switch controller. In both cases rewasd works perfectly fine.
Now I need to get a new controller and I feel that the Razer Wolverine V2 Chroma could be what I need. So I have many questions about the support rewasd has towards this new version.
1. Does rewasd recognize the controller? can I configure it?
2. Razer Wolverine V2 has a regular version and the Chroma version, is there any difference of support towards this two versions?
2. The four START/SELECT buttons that there is in front of the controller, are they configurable?
3. Am I able to configure the M's buttons? I have seen that for the first version of this controller it is not possible, but is it possible for the V2? I haven't found information about it. If it is not possible, is there any chance rewasd could get the support for it eventually?
Thanks for all.
Thanks for all.
