Hi, im playing csgo with my xbox controller mapped to kb&m, is it possible to make my LB turn 90 degrees left and my rb turn 90 degrees right with a tap? if so how?
Need help
I only need to use flick stick temporarily for quick big turns so when I leave go of LB im back to using the right stick as a mouse. Another question I have is, is it possible to make it so my right stick when used a flick stick can I make it so It only registers as a kind of cross? So left would be 90, right would 90 and down would be 180 but if I push down on the stick but not perfectly down lets just say down but a little to the left it will only register as down (kind of like a cross deadzone?)
This is how it should work by default. Perhaps you need to adjust the sensitivity differently. Try to follow the recommendations from this guide.
