Sticks too fast
  • Sticks too fast
    Hello everyone. I'm new on this forum. Sorry for any inconvenience.
    I have an Xbox Elite with reWASD 6.1.1 and Windows 7 and I use the left stick for up/down/right/left view movement.
    I would like to know what steps I must take to configure the left (or right) stick so that the movement is slow.
    Now when I move the lever everything moves very fast.
    Can someone guide me?
    I don't know if this is the right place to ask this question.
    Thanks in advance.
    foscmgt
    Hi!
    The configuration required depends on how you are remapping your controller.
    The "I use the left stick for up/down/right/left view movement" description is unclear. Please upload a config file you are using.
    To find the file right-click on its name at the top left corner and select [Open file location] option. To upload the file use the [Upload Attachments] button on the forum page when replying.
      Hello! Sorry for my poor explanation. I attach the 'Config 1.rewasd' file. The problem mainly arises when I move the joystick left stick left/up/right/down. The movement that is obtained is too fast and the view on the screen is done suddenly instead of gradually. Is there any parameter that allows the movement to be smoother or slower? Thank you foscmgt
        It is currently not possible to make it slower, but we are already looking for a way to implement it. We will let you know when there is news.
          Hi!
          just create a custom negative curve on your right sticks advanced settings.
            OP uses arrow mappings on the left stick. Our Response curve influences only analog movement — if a stick or a mouse are mapped there. We do plan to implement curves for keyboard digital keys, but at the moment, this functionality is not ready yet.
              Ok. Thanks.
              So I'll wait for the implementation.
              Regards
