Single input's iterations in macro(Key Combo)
  • Single input's iterations in macro(Key Combo)
    Hi, I have a macro like "ABBBA", and want to simply write that like "AB(iterations=3)A".
    But I can't find any function for single input's iterations in macro(key combo).
    Is there any function which can do it?
    Nope, there is no way to iterate a few nodes in a combo like you describe. You will need to put all three of them manually. Thus, that's a good idea, and we will consider implementing it.
      Thank you. I can wait for this function coming, I will put all three of them manually.
        Will let you know once it is ready! Thank you!
