Thank you!
You have at least two drivers that may influence here. Please start from hidguardian (its main purpose is to hide the gamepads, so it should be removed for sure). You may check the official removal guide here. Also, there is vigem, it may misbehave too, but first try to remove hidguardian, restart your PC and re-check if your physical and our virtual controller appear in joy.cpl. If you see the same, remove vigembus too.
