Not sure if there is anyone else out there using REWASD with PUBG but I thought it would be cool to get a topic going on the subject. I am looking for tips, tricks, etc. to make playing PUBG with a controller a little easier. If you've had success with specific configs or layouts, please post them here. Below is a list of questions I have specifically. Thanks in advance for contributing!
1) Virtual Mouse Settings - Where do you have your sensitivity, acceleration, and initial speed set?
2) Anti-Recoil - Has anyone had any success using REWASD to create an anti-recoil setup with PUBG or similar games?
3) Settings - Any particular settings tips and tricks would be super helpful (so many settings to mess with, I'm a bit lost).
4) Xbox Elite - Does anyone have any suggestions specific to this controller type for PUBG?
I've also attached my config in case anyone wants to check it out. Thanks all!
