Free trial ended without using it.
  • Free trial ended without using it.
Name:	Screenshot 2022-07-04 112212.jpg
ID:	232819 Got the software and it displays a message saying "It was a pleasure mapping for you during the trial period. Shall we go on?" Making it impossible for me to use. I cant click anything around it either. I tried disabling potentially unwanted apps in Windows Security, re-installing, and restarting my PC although none worked. If anybody could help me that would be appreciated.
    This pop-up window really informs that the trial of our application has ended.
    As soon as you launch reWASD on PC for the first time, the 7-day trial of the application starts automatically.
    If you are the owner of a paid reWASD license, you just need to click on "I already have a key" and enter your serial number.
    Or click on the "Buy Now" button and purchase the set of functionality you need.
      That's weird because I installed the application just a few hours ago. Is there anyway to fix it or is it forcing me to buy it?
        To prolong the trial period for you, I need to identify you in our database by a system ID. Please download this tool:
        Launch it, copy SID that will be revealed and send it to me. You can do this in the form of a private message.
          can u also help me with that i just download and now it says the same thing
            Please follow the message above by 1ncorrect and send us your system ID in DM.
              the link is not working
                Try opening it in a new browser tab.
                  it is working and are u a mod so u can help me with this?
                    Shion are u a mod
                      Yes. Let's continue via the Direct Messages.
