Have I got burned again?
  • Have I got burned again?
    Hi there,
    I got reWASD +advanced mapping to fix stick drift on an old 360 controller.
    I followed the instructions here.
    https://www.rewasd.com/blog/post/how...ft-with-rewasd
    The stick drift is fixed but all my diagonals are dead.
    I'm wondering if anybody knows what the story with that, is that what they call 'fixing' stick drift? Or am I missing a set of instructions I wonder?
    Thanks
    Hello.
      Thank you. I believe this is the profile I tampered with.
        In order to fix stick drift, it is enough to increase the gray area in Advanced stick settings.
        In case you are remapping the stick as a stick, you must also check the Affect gamepad behavior for games checkbox.
        No additional action is required.
        Your config also has a Use 8 digital directions checkbox, which allows you to create digital mappings for diagonal movements.
        You just need to uncheck this box.
          Sorted. Thank you very much. It's resurrected a bunch of dead controllers I can stick with the old clunkies. I really didn't get burned again! Good stuff. Thanks.
            We are always happy to help
