The mute toggle does not work for me. If I program something it sends both the programmed input as well as the native input. Doesn't matter if I have the mute toggle on or off. Even if I change the native setting to mute. Neither works.
Mute not working
You have to set the paddles of your Xbox Elite controller to "unmapped" on every profile in the Xbox Accessories app first.
And make sure you do not update the firmware of the controller, so it stays on version 4.8.
Check this article for details.
