I could be doing something incorrectly but I need the d-pad to use the assignments I give in the main layer (which mutes native functions), but when in shift 1 layer it has its native function. When I attempted to do this, even though I got a notification that I was now in Shift Layer 1 (is there anyway to turn that off btw?), pressing up on the d-pad still resulted in it behaving as if I was in the main layer. The type of shift I went with was toggle.
Thank you
EDIT: Uploaded Attachment of Config
Thank you
they will have native values.
