No Mouse Movements
  • #16
    Feel free to purchase a license with at least the Advanced Mapping feature and use reWASD not just for a few more days but for a lifetime.
    • #17
      hearts Are you sure you have the Full Pack reWASD license and not just the basic one?
      For mouse-to-stick mapping to work, you must have the [Advanced Mapping] feature activated. If it was on a 3-day Trial Period, it has expired by now and no longer works.
      Otherwise, please ensure you have the correct mouse device in the group you are remapping. You can use the [Device detection mode] to check that. Follow the instructions in case #24 here to fix the issue.
      No I stated above I paid the full version. I also stated I used the device detection and it still doesn't move the mouse.
      • #18
        Please check if your config works correctly in the tester: https://hardwaretester.com/gamepad
        Also, please record the process on video.
        • #19
          Im having same issue, before when i would start rewasd i would loose control of the mouse, and had to click capslock to gain control ,and do my stuff and then activate again in game
          Now i always have control of the mouse and when i go in game i can shoot and aim , but can't move character
          Pls help
          Thanks
          • #20
            wildpombo The group of devices you are remapping must have changed. Please follow the instructions in case #24 here.​
            Note: Your license must include the [Advanced Mapping], [Combo], and [Rapid Fire] features for this config to work.
