During the following month I need to temporarily use ReWASD on another machine then move it back to my original machine.
1. License transfers
I have never done that but the instructions seem simple enough
Is there a limit to the number of times that I can transfer the ReWASD license? e.g. Max 100 times?
Can I theoretically keep moving it back and forth if I need to?
2. Portability
ReWASD isn't a portable software. (as in, move the folder and you're done, e.g. https://portableapps.com/ and many other software)
ReWASD seems to create many folders all over the file system, as well as installing device(s) and possibly (haven't checked) registry keys. It might also install hidden files/keys etc. for the license track
Other similar software, DS4Windows For example, is somewhat portable since it's enough to move the folder.
When running the DS4Windows executable for the first time on a new machine, it will install any required drivers libraries or support software.
3. Moving ReWASD
Besides copying the \reWASD\Profiles directory I want to maintain my complete settings and setup (including custom paths, devices, etc)
My thinking is:
a. revoke the license on daemon-tools.cc
b. zip the ReWASD folder on the old machine
c. Install ReWASD on the new machine
d. delete the main ReWASD folder created on the new machine
e. replace it with the .zip content
f. run ReWASD on the new machine and apply the license
g. reverse the procedure when moving back
Will this be enough to have a perfect copy with absolutely all settings, devices, profiles, etc?
I am worried because on my system, I count at least 9 difference folders where ReWASD is keeping data (maybe trash in some cases)
For example:
\AppData\Local\Disc_Soft_Ltd\reWASD.exe_Url_xxxxxx xxxx\6.4.0.6988\user.config
\AppData\Roaming\Disc-Soft\reWASD\Logs\REWASD_driver.etl
C:\ProgramData\Disc-Soft\reWASD
C:\Windows\assembly\NativeImages_v4.0.30319_32\reW ASDEngine
There are many many others I will not list them all
Conclusions:
- are the steps above enough for a complete transfer?
- will ReWASD become more portable-friendly in future? is this on someone's ToDo list?
I need a reply quite soon since I need to transfer the license in 1-2
Thanks
2. Portability
3. Moving ReWASD
My thinking is:
For example:
Conclusions:
Thanks
