so there is some kind of conflict problem, when rewasd is active and i open a game via steam the controller just dont work at all NOTHING!, if i switch to a config that is blank in rewasd, the controller then works but my back paddles no longer work, not all games pick up the paddles via steams input im completely confused by this
coflict Problem
1. Apply the config. Open gamepad tester and check if the mappings work
2. Please send me the config you are using. Your configs are stored here: C:\Users\Public\Documents\reWASD\Profiles
I need the corresponding *.rewasd file.
yeah all configs and non set configs work in gamepad tester, the reason i know this is cause there is no configs on 2 of the profiles on my elite 2 so slot 1 and slot 2 have configs in rewasd and slot 3 and slot 4 do not have configs in rewasd they are blank and when i turn off rewased remap slot 1 and 2 work on steam fine but then i have no configs for back paddles now soo . . . not really a solveAttached Files
If non-empty configurations work fine in the tester, then there is no problem on the reWASD side and this is most likely a conflict with the Steam remapper.
As we recommended earlier, disable controller support in Steam so that only our mappings work in the system. If at the same time the game does not detect the gamepad at all, we are unlikely to be able to help.
This is one of the tricks of Steam – providing controller support in games that do not natively have it.
