Not sure if I'm just being blind, but I want to create a key combo that does the following...
On Key Press = Combo: Press 4, Release 4, Press Left Mouse Button + Hold.
On Key Release = Combo: Release Left Mouse Button, Press 1
So I need to be able to "delete" the mouse button up action but keep the mouse button down action. It seems deleting either deletes both
When I use the combo editor, it appears key presses can ONLY be entered as either 1) Holding all or 2) press / release indidually. I could've sworn I *used* to be able to do what I want!
Is this not possible?
