I had some problem with MAME awhile ago ... it requires controller to be present before MAME starts in order for that controller to be detected and be usable in MAME. This was solved with Leave Virtual controller connected when the physical device disconnects.​
Now similar problem with PCSX2 (versions that support DS3 sixaxis that ReWASD team baked into PCSX2 ... again, thanks to ReWASD team). If I start PCSX2 normally and launch game from PCSX2 - everything works. But if I launch game from command line with somthing like
pcsx2x64-avx2.exe --fullscreen --portable "some game file"​
PCSX2 does not detect Virtual Controller. Important point - ReWASD is set to automatically apply DS3 remap when PCSX2 is in focus. If I manually apply remap and then use command line - everything works.
So my guess - Virtual Controller does not initialize fast enough even with Leave Virtual controller connected when the physical device disconnects​ option. Am I doing something wrong?
Thanks in advance for your help.
