Don't fire keys for switching layers with shortcuts
  • Don't fire keys for switching layers with shortcuts
    I'm trying to change layers with shortcuts in place of . I have the following setup:
Name:	2023-07-14 02.02.34- 01222.png
ID:	238295Click image for larger version
Name:	2023-07-14 02.02.34- 14899.png
    Despite having the option "Re-press the held button when switching the Shift layer" unticked, when switching layers, sometimes characters still appear. I can't seem to enable the mute button either.
    Is there something I'm missing in my setup?
    Could you send me your config?
    Your configs are stored on your computer along the path: C:\Users\Public\Documents\reWASD\Profiles​
      Here you go
        "Re-press the held button when switching the Shift layer" option is not related to Shortcuts. There is no way to Mute the keys that are used in a shortcut
        As an option, you can adjust any key as Jump to Shift and Mute it.
          I was hoping to be able to use shortcuts / combination of keys to switch layers as I need the native behavior with other keys / already have macros on those keys.
            If you use, for example, A + D shortcut to go to another layer, the A key will be reproduced every time, so the native behavior of A key still persists.
