New-ish rewasd user here. I had been using rewasd with the Apex 2 with no issues for a while, and recently switched to the Vader 3. I've been encountering intermittent issues in which the Vader 3 will remain connected (The LED does not change, Windows doesn't detect a hardware change, etc) but rewasd will stop reading inputs. For example, I'll suddenly lose control in a game, alt-tab, and see buttons aren't being highlighted in the rewasd app when I press them on the controller. Any ideas?
Vader 3 Connectivity
And how about to contact Flydigi to release a Firmware Update because your CUSTOMERS having trouble with the Vader 3 Pro?Originally Posted by DevX View PostSorry, we cannot find solution for this issue at the moment. It can be solved only if Flydigi makes new firmware for Vader 3 Pro and maybe its dongle.
So for my part, I am not a free user.​
Not an issue on my end. I am not sure how many users have the wired connection as the dongle / wireless is preferred (at least for me), especially using the gyro. I only switched to wired because of the connection issues with wireless; only to have the same experience.Originally Posted by DevX View PostWe have never experienced problems with Vader 3 Pro on wired connection and you are first to report this ever. It is rather some hardware USB problem on your side then.
