Searched around for answers. Getting quite an fps hit in Warzone when aiming down sights. I've checked that everything is muted and as far as I can tell everything is as it should be.
If possible, could someone take a look at my config. It's an altered config that I found online and I'm pretty new to this so easily could be missing something silly.
Beware that some key binds are a bit unorthodox, but after nearly 30 years of shooters, it's too late to change now. The most obvious are space to prone and right mouse to jump and R to aim down sight. The most obvious hit to fps is when I aim down sight with R.
Thanks so much for anyone taking the time. Let me know if I'm leaving out any required info.
