I've been using your guy's software for quite awhile now and it's been great.
But I'm currently running into an issue and want to see if anyone else has had this issue.
Essentially what happens is when I have the Vader 3 pro (V3P) gyro set to mouse, randomly when I'm playing the mouse will slow down to about half sensitivity for up to 5ish seconds and then speed back up to normal. it's not super consistent and can't seem to find a way to trigger it to happen. I'll list below what I've done to test but I'm gonna assume it's on flydigi's side of things.
1. this is actually my second V3P, the first one had the exact same issue and thought maybe the controller was just defected.
2. I turned off all smoothing and left the curve in advanced settings to a straight line to keep it linear.
3. tried different games to make sure it wasn't a game specific issue.
4. tried another computer to make sure it wasn't my computer being wonky
5. different cables/usb ports. tried with dongle and wired.
6. I switched it to 'switch' mode and in that mode the gyro actually works flawlessly in rewasd/steam input/JSM but you obviously lose the extra button remap.
7. went back to using the apex 2/DS4 and those two work fine with no issues
8. The sticks/buttons don't seem to 'slow down' with it, just the gyro. thought maybe the polling rate was getting halved.
Appreciate any response or help if possible. Thanks!
