Hello, I'm trying to uninstall the program but it seems that it's crashing every time and doesn't open under any circumstances
Can't uninstall reWASD
Hi.
Please check for errors in Event Viewer by following the steps below:
1. Press the Windows button, type [Event Viewer], and press Enter.
4. Once you find one or multiple events, please right-click and "Save selected events..." on every one of them, and send the file(s) to me.​
Sometimes a color profile assigned to your display(s) can be corrupted and cause .NET to crash and stop anything from working. Please try temporarily changing the Device profile and Viewing conditions profile options to use System default from the dropdown list in Color Management → Advanced → Windows Color System Defaults and try launching reWASD again.
