Destiny 2 - disables keyboard and mouse if using Joystick
  • Destiny 2 - disables keyboard and mouse if using Joystick
    I don't remember after which update, but I can no longer use the mouse and keyboard in Destiny 2 if I enable any customization on the Joystick.
    I've tried grouping the controls but it didn't make any difference.
    Any tips?
    Sorry for the English, google translator helped me. ​
    Hello.
    What exactly is the issue:
    Is it that when a virtual gamepad is emulated, your keyboard and mouse stop working as a keyboard and mouse?
    Or is it that the virtual controller does not work in the game when you apply the config?​
      Hello.
      It doesn't matter if it has a virtual joystick or not.
      I noticed that when I enable some feature, such as joystick autofire in RT, the keyboard and mouse stop working in the game.​​
        Could you record this on video?
        Thanks in advance.​
          Thanks in advance.​
          No problem.
          Here:
            Could you please clarify if this issue occurs in other games?
            Also, please send us your config. Right-click on its name, open the file location, and send it to us.​
              No, it doesn't happen in other games, I tested it in Warframe for example, which also changes from joystick to mouse and keyboard automatically.
              If you notice in the video at 1:30 when I turn off REWASD, the way Destiny works, the game deactivates and activates control as the keyboard and mouse are used.
              I would like to point out that this did not happen until a few versions ago, I believe it was from versions 7.x onwards I will do a test by doing a downgrade.
              Attached are my settings.​
              Thanks in advance.​
                Your video and config suggest that you do not remap your mouse and keyboard to a virtual controller together with your physical one.
                Technically, reWASD is not related to this issue. The game simply does not allow dynamic switching between the controller and K&M during gameplay. We suggest you contact the game's support team to verify that.
                Note: You should probably set a higher value for the [Turbo] option on [Shift#1] as it might not work consistently if your game runs at FPS lower than 66.
                  The game works well until I enable autofire in REWASD, so I believe it is not a problem in the game, it even worked previously, I must have done something wrong and will do more tests.
                  About autofire I play at 116 FPS, autofire works fine as is, but thanks for the tip.​​
