Create a Mouse +Keyboard combo
  • Create a Mouse +Keyboard combo
    HI,
    I am playing Ghost of Tsushima on PC. I want to create a combo whereby I click on Shift + LMB and it performs a keypress on the keyboard.
    I tried to create a group that combines my keyboard and mouse but I don't see how to do this or if it's even possible to do these types of combos of mouse and keyboard.
    Thanks
    Hello.
    How you can create a device group is described in this article.
    If you want to physically press 2 buttons and emulate some kind of virtual input, then Shortcuts will help you.​
      Thank you, Shortcuts worked!
      When I try to combine a keyboard key with either the LMB or RMB, I get a message that this will disable the mouse, and indeed the mouse gets disabled when I do that combo. Is that a limitation of the software only allowing combos with the other buttons?
      Also is there a way to insert a small delay between the keyboard press and mouse press?
      Thanks
        Can you send here screenshot of the message you are talking about?
        If you talking about "window", in which you need to press the required buttons, then it can be found here:
          The message doesn't appear anymore. But now, the combo works for mouse button + Keybord.
          However, the original function of the mouse button also triggers. So a combo of LSHIFT+LMB=9 will type '9' but also press the LMB. How can I disable that?
            You need to map the physical LMB to itself and apply Mute to it in the mouse subconfig.
              Thank you SO MUCH. This worked like a charm.
