Rewasd Installation Issue
  • Rewasd Installation Issue
    I install with the setup, but I get the following error - "windows cannot access specified device, path or file you may not have appropriate permission"
    I have tried running as admin, but it doesn't work. Then I tried installing .NET manually, but no luck.
    Even after getting this error, it gets installed but then when i try to run it I get the "rewasd background agent could not start" error
    Please help​
    The cause of permission issues usually happen due to anti-virus, security, or some other third-party software interference.
    Disabling those before installing and starting reWASD is usually a solution.
    But if that would not work, it would only leave the option of doing a clean reinstall of Windows.
    Please note that reWASD might not work on "Lite" or custom versions of Windows, as they usually lack required components.
