Switch Pro Controller using Bluetooth 5.2 adapter on ROG STRIX B660-I GAMING WIFI.
My character was not fully running in the upper-left diagonals.
Checked out circularity using webapp linked above.
Windows gamepad calibration cannot fix this.​
I thought it was joystick hardware failure.
Wired PC connection inexplicably fixes it!
I can fix wireless circularity by using a custom joystick graph to achieve 100% input just slightly before a full tilt-- but that seems like a bit of a dirty fix, especially considering a wired connection does not have this issue despite using the same controller profile.
EDIT: POSSIBLY RESOLVED
Updating reWASD to the latest version and/or rebooting my PC seemed to fix this. I will continue to use a regular straight curve graph and watch out to see if the problem comes back.
