I've been using reWASD for awhile now with no issues. Recently started having issues with reWASD for some reason. The controller I'm using is a flydigi apex 2 plugged into my pc via cable. Whenever I'm using the "xbox one" remap options the A,B and Y buttons seem to be registering as multiple inputs. Whenever I press A it always registers as if I'm pressing Y&A at the same time. Pressing X = AX and pressing Y=YX. I've always used the xbox one remap options as it's my preferred option. However whenever I use any of the other options this doesn't happen and all the inputs are correct. This only happens with xbox one remap.
Is there any reason why this is happening? Also I'm not sure if this was happening before as well but now whenever I alt, control, delete out of my game its saying that reWARD magic is off with the power button grayed out. I don't remember that happening before either.
