Hi. I'm still learning new things. Is it possible for me to use combos with ps5 controller for Mortal Kombat 1 on PS5 if I use Remote Play with REWASD? Ive seen you can use keyboard and mouse but I'm not sure if they can use combos on there keyboard, and that gave me the idea about the PS5 controller but is it possible to do this? I have 2 beefy PC 'sand a PS5.
PS Remote Play
Hello.
I'm not sure if the Remote Play app will detect input from a keyboard button combo.
As an option, you can try to apply to a physical controller. However, to use in PS RP, all mappings must be gamepad. Thus, applying the config, the system will still detect your controller as DualSense.​
