So I'm somewhat familiar with Shift Layers, but I was wondering if rewasd can perform a specific thing.
Basically what I want is for one button to briefly mute another button, but to quickly unmute again even if I hold the second button. For example, if I'm holding down Square first and then hold down X, I want to mute Square only at the moment X is initially pressed, but then have Square quickly return to the pressed state even if I continue to hold X.
So I set X to jump to a Shift Layer where Square is muted. The Hold and Toggle modes wouldn't work for this so I assume I need to use the Custom mode if this is possible, but I can't seem to figure it out. Is there any way to automatically return to the Main Layer after a set amount of time? I just want the shift layer to be activated for a few milliseconds no matter what. Maybe a key combo or something would work I'm not sure. Any ideas would be appreciated.
