Analog input got cancelled from another input?
  • Analog input got cancelled from another input?
    So I remapped the left analog stick to WASD for my game's movement input, everything is fine, except I found out if you fire another input (let's say a mouse left click), the movement will stop even if I was still holding down WASD, I need to release the WASD and push it again to resume the movement, that got pretty annoying and I don't know if there is a way to fix that.
    This kind of behavior shouldn't happen.
    I need the correspondent *.rewasd file.​
      Ok then, I use this for the game Bloodborne if you need to know
      BloodborneControl.rewasd
        I checked your config here and found no problems.
        Maybe in the game it works like this because of constant switching of input from kb&m to controller.
        Try to enable Mute for all mappings in your config.​
          I'm pretty sure my input was all Mute enabled to begin with?
          Or is it another way around that I need to turn the button off?
            No, that's correct.
            However, please clarify whether you are trying to play Bloodborne via Remote Play or via an emulator.
