I have remote play for PS4 set up and working. I have REWASD installed. I have my PS4 controller connected to a laptop. I open REWASD and choose the X button for the PS4 controller to remap. I choose single click, execute at once, record a macro, press X on the controller multiple times, then stop recording. I go back and check the Toggle option. And then what?
After doing this, I press X on the controller and it just does an action once as though I was playing normally and never recorded a macro. I unchecked the Toggle option and checked Turbo instead and it did the same thing. I went to the lower left corner of the screen and hit the power button icon to turn [something] on and the controller stopped responding until I turned if off again.
All I want to do is record and play a macro that will repeat the X button action on a PS4 controller over and over until I stop it. I feel like this should be simple but this program is too advanced for me to figure it out and I need help. I will gladly buy the service if I can get this working before the free trial ends.
