I've got an XBOX elite 2 controller, using it over bluetooth.
The problem I'm having is if I map the output as a "Virtual Xbox 360" or xbox one controller the left trigger doesn't get picked up as an axis, specifically in DCS.
But if I map the output as a "Virtual DS4", then I can map as an axis no problem.
There's a problem with that too though because if I map output as a DS4 then my screen saver no longer works.
And I really don't want my monitors burning out when I walk away and leave my PC running.
I'd really appreciate it if I could get some help with either of these two issues, don't mind which one!
Thanks!
Thanks!
