Gyro Drift in both Vader 3P and Vader 4P
  • Gyro Drift in both Vader 3P and Vader 4P
    I just upgraded to the V4P thinking that I could get rid of the slight gyro drift (all directions) at times. However, I have the same issue with the V4P.
    While I imagine that this is a hardware issue, is there anything that REWASD may be able to do (even in a future build) to mitigate this issue?
    Hi!
    The gyro drift you’re experiencing with both Vader 3P and 4P is likely a hardware-related issue, as it is often caused by internal sensor calibration. However, reWASD provides some tools and suggestions that might help mitigate the issue:
    1. Calibrate the Controller:
      • Check if your Vader 4P has a built-in calibration feature for the gyroscope. Many controllers offer this option, and it may help reduce the drift.
    2. Calibrate the Gyroscope in reWASD:
      • Use the Gyroscope Calibration option to adjust and stabilize the gyroscope sensor directly within the app.
    3. Adjust Sensitivity:
      • In reWASD, you can also tweak the sensitivity and deadzone settings for the gyroscope to minimize unintended movements.
      You can find step-by-step instructions for configuring gyroscope settings in this helpful guide.
      Originally Posted by Kapas View Post
      Hi!
      Thanks for your response. It appears that REWASD does not have the calibrate option for the V4P, but I will look into the other suggestions.
        The simple way to calibrate gyro drift on Flydigi controller is just to put it on the table and don't touch for a couple of seconds - it will autocalibrate automatically.
