Can't use more than one shift layer
  • Can't use more than one shift layer
    I have been using reWASD with multiple shift layers for years. I have a number of profiles using the main layer and shifts 1 and 2. They work fine. I can modify them.
    I just tried to set up a new profile from scratch and it let me have shift layer 1 but wouldn't allow me to have any further shift layers.
    Here is an old profile using multiple shifts that works fine:
Name:	Rewasd 1 (old).jpg
    And here's a new one I just tried to create:
Name:	Rewasd 2 (new).jpg
    Additional shift layers are unavailable. What's going on?
    Hi!
    Try to use this button to add a new Shift Layer:
      Thanks. I was able to get that to work, though it took a few tries.
