​ Hi,
Could you help with issues noted bellow?​
Problem 1
reWasd 9 shows error nag regarding guard64.dll when controller gets connected. guard64.dll file belongs to COMODO firewall/antivirus software which operates properly. Reinstallation of COMODO did not help at all.​
Problem 2
On reWASD 6 version (and older) I could press reWASD mapping selector (marked in red on picture) and then I could type any letter or number directly from my hardware keyboard. ​
In reWASD 9 or 8 I couldn’t do that. If, for example, I want to enter letter K, I have to scroll through all the list of keyboard keys and find K letter that is needed. Hardware keyboard no longer can input letters or numbers directly. That is very inconvenient.​
Thank you!​​
Problem 1
Problem 2
Thank you!​​
