I game with a mouse and remapped gamepad, but the analog sticks lose out on functionality that I know exists in the controller- that is, the left stick is WASD or nothing, but were I using controller only I would be able to lightly press the stick and have the character walk instead of run. I had written it off as a limitation of my setup, but found the wooting keyboard, with full range switch motion. haven't bought one, haven't tried it but it seems like that would be the sort of thing that allows for a light press to output as a walk, and I want to know if rewasd can output the same sort of signal and have games pick up on it. Cant leave it as a stick, most games i've played freak out when you try to mix and match
ReWASD Full analog Motion
There are no plans for that at the moment, but - never say never.Does not support them or does not support them yet?
Unfortunately, no, there is no option to prevent that (at least from the reWASD side).​ If the game allows you to choose input type, then this might be a solution.Is there a way to leave the stick as a stick in a way that doesn't make games panic and switch inputs between xbox & mouse+keyboard that you are aware of? I technically don't need it to map to WASD
