Hi
Running into something odd with rewasd and hoping someone can help me figure this out. The goal is to map right mouse button to the controllers left trigger for ADS, and map left mouse button to the controllers right trigger for fire, then layer some small stick movements while holding fire. RMB to LT by itself works fine, but once LMB to RT + stick combo kicks in, things get wonky. I instantly get snapped downward to the ground. What could be the causing this?
For a little more info I'm not trying to emulate the full controller to my M&K. I still want to use M&K but since rewads doesn't support mouse movements for now when making combos I'm using the controller stick movements and triggers instead.
