Hi, I’m wondering first if there is already a ready-made reWASD profile for Path of Exile 1 that allows:
WASD movement
Game in Controller Mode
Mouse cursor still free
Left-click acting as Controller Button A
Other mouse buttons or keys mapped to X/Y/B/LB/RB
I only found profiles that go in the opposite direction (controller → keyboard/mouse).
If there is already a profile for keyboard + mouse → virtual controller for PoE, I would love to use it or start from it.
If such a profile doesn’t exist, here is what I am trying to achieve:
Goal: Play PoE in Controller Mode while controlling it with:
W/A/S/D → Left Stick Movement
Left Mouse Click → A (interact / loot / NPC / waypoints)
Mouse remains free to move normally (no cursor lock)
Other buttons mapped as needed for skills (X/Y/B/LB/RB)
So essentially: Keyboard + Mouse → Virtual Xbox 360 Controller
but with real mouse cursor input still active.
What I have working already:
Virtual Xbox 360 controller output is enabled in reWASD.
I successfully mapped WASD → Left Stick and movement in game works perfectly.
I also mapped Left Mouse Button → A, and it does send the A-button signal in PoE.
So the base idea works.
The Problem:
As soon as I activate the config that maps Left Click → A,
the mouse cursor becomes locked / captured / suppressed in game.
I can no longer freely move the cursor to aim, interact with UI, hover items, etc.
The only way I can get the cursor to move is by holding Windows key, which is obviously not usable.
So it looks like reWASD is enabling some kind of:
Input blocking
Exclusive mouse mode
Raw mouse masking
Or virtual mouse takeover
I need cursor movement to remain normal while sending controller button events.
My Questions:
1. Is it technically possible in reWASD to keep physical mouse cursor input active while also using the mouse to send controller-button signals?
2. If yes, which exact setting disables the mouse-locking behavior?
(For example: group settings, exclusive mode toggle, “emulate mouse on behalf ofâ€, HID mode, etc.)
3. Is there a recommended configuration or known working setup for PoE specifically?
4. And again — if there is a ready-to-use WASD-for-PoE profile, I would absolutely prefer to use that instead of building from scratch.
Device Info:
Path of Exile 1 (PC)
reWASD (latest version)
Keyboard: Corsair
Mouse: Razer Basilisk (recognized and remappable in reWASD, but appears as "initialize first" when trying to group with keyboard)
Thanks in advance — any guidance, profile link, or explanation of how to allow mouse cursor passthrough while mapping controller buttons would be greatly appreciated.​
WASD movement
The Problem:
Input blocking
Raw mouse masking
My Questions:
Device Info:
Keyboard: Corsair
