reWASD says mapping is invalid, but it works
  • reWASD says mapping is invalid, but it works
    Hi, I made a mapping that resets the left stick before inputting a combination and then I got this warning:
    It tells me that the mapping should not work, right? But it DOES work in the game.
    When I remove the deflection mapping, DOWN+X is not registered by the game when LS is pointed upwards. The direction is canceled out by the stick, so it registers X only.
    WITH the deflection mapping, the game will register DOWN+X consistently regardless of LS position.
    It seems the warning should not be there?​ It works so I can just ignore it, but it is a bit strange.
    Emulation is set to the physical device (Wolverine V3 TE).
    Screenshot of the mapping:
    ​​Click image for larger version
    Hi. Could you send us your config?
      Sure, here you go.
        These mappings cannot work when 'Apply to physical' is selected.
        If you are sure they work on your side, please send us a video demonstrating it.
        Please use this tester for the demonstration.​
          I can reproduce it with this tester. I made a simple config that maps Y button to LS up (relative) and XBOX button.
          The XBOX button shows up as B16 in the tester, so you can see when I press it.
          Video: https://jumpshare.com/s/MmNDzLh5ynqTTICw0gNT
