Xbox Elite Wireless Controller Series 2
  • #16
    Strange, as unmap completely mute the native controller inputs so only keyboard mappings work. I made short footage where you may see that triggers and mapped F buttons fire at the same time (take a look at viewkeycode and HTML gamepad tester). But as soon triggers are unmapped, only keyboard mappings are active.
    May I ask you to check one more time if the triggers were unmap like video shows, otherwise I would appreciate it if you collect apply log:
    - Go to the C:\Program Files\reWASD and create a shortcut of the process.
    - Find the icon on the Desktop (1) and open Properties via contextual menu (2) and type -tracetext (3), like this.
    - Run reWASD with created shortcuts, do mappings with unmaps and press "Apply"
    - Go to the C:\Users\Public\Documents\reWASD\Logs and send us TextTrace - Apply [Config 1].txt text files.
    Thank you in advance.
    • #17
      As I am a 3dvision user I am unable to update to the windows version 1903 due to broken support. I just realized before I bought this controller back home from the store that 1903 is required to use the default app. So you guys are my last hope =)
      • #18
        I see. Will try the best. Still, you may send us trace log requested above to see the mapping sequence after apply.
        • #19
          Sorry to bother you, but are there any updates regarding supporting the paddles? Thanks
          • #20
            We are going to release the update on Friday this week.
            • #21
              Great news! I look forward to being your guinea pig. I think my first test will be mapping more controls in Elite Dangerous.
              • #22
                The wait is almost over. The release is scheduled for tomorrow.
                It's a perfect time to start choosing mappings you need on paddles :satisfied:
                • #23
                  I've temporarily switched back to mouse and keyboard for the time being, waiting for new updates to hopefully solve these issues.
                  Where is the footage you have mentioned? Can't find the link in your post...
                  I'll provide the logs when I get back home from work later!
                  • #24
                    Here is the footage link - https://streamable.com/eknfv. And we do appreciate it for the log.
                    • #25
                      OK got it! Seems to be working on your side, will try again tonight and give some feedback!
                      • #26
                        Here are the logs:
                        reWASD: 19:03:12:479 >>>>>>>>>>>>>>>>>>>>>>>>>>>
                        reWASD: 19:03:12:481 Config path: "C:\Users\Public\Documents\reWASD\Profiles\Wor ld of Warcraft\Controller\WoW.rewasd"
                        reWASD: 19:03:12:481 reWASD version: 5.1.0.1302
                        reWASD: 19:03:12:518 ParseConfigFile return success
                        reWASD: 19:03:12:533 VirtualGamepadMapping: not exist
                        reWASD: 19:03:12:533 HideOriginalGamepad: false
                        reWASD: 19:03:12:537 ShiftModificator 1: Gamepad [XB: BtnLeftUpperPaddle]
                        reWASD: 19:03:12:537 ---
                        reWASD: 19:03:12:537 "Compile Main"
                        reWASD: 19:03:12:546
                        reWASD: 19:03:12:546 --- Gamepad ---
                        reWASD: 19:03:12:546 ControllerIndex: 0
                        reWASD: 19:03:12:548 ControllerType: "Xbox One"
                        reWASD: 19:03:12:548 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:12:566 Unmap [Main ] Unmap -> Gamepad [G 0: LeftThumb]
                        reWASD: 19:03:12:566 Unmap [Main ] Unmap -> Gamepad [G 0: RightThumb]
                        reWASD: 19:03:12:566 Unmap [Main ] Unmap -> Gamepad [G 0: LeftTrigger]
                        reWASD: 19:03:12:566 Unmap [Main ] Unmap -> Gamepad [G 0: RightTrigger]
                        reWASD: 19:03:12:610 Activator [Main ] Source -> Gamepad [G 0: A]
                        reWASD: 19:03:12:610 Mapping -> Single: (0x57 - DIK_F11)
                        reWASD: 19:03:12:692 Activator [Main ] Source -> Gamepad [G 0: B]
                        reWASD: 19:03:12:692 Mapping -> Single: (0x44 - DIK_F10)
                        reWASD: 19:03:12:693 Activator [Main ] Source -> Gamepad [G 0: X]
                        reWASD: 19:03:12:693 Mapping -> Single: (0x58 - DIK_F12)
                        reWASD: 19:03:12:693 Activator [Main ] Source -> Gamepad [G 0: Y]
                        reWASD: 19:03:12:693 Mapping -> Single: (0x43 - DIK_F9)
                        reWASD: 19:03:12:693 Activator [Main ] Source -> Gamepad [G 0: LeftShoulder]
                        reWASD: 19:03:12:693 Mapping -> Single: (0x2A - DIK_LSHIFT)
                        reWASD: 19:03:12:693 Activator [Main ] Source -> Gamepad [G 0: RightShoulder]
                        reWASD: 19:03:12:693 Mapping -> Single: (0x1D - DIK_LCONTROL)
                        reWASD: 19:03:12:694 Activator [Main ] Source -> Gamepad [G 0: View (Back)]
                        reWASD: 19:03:12:694 Mapping -> Single: (0x3F - DIK_F5)
                        reWASD: 19:03:12:706 Activator [Main ] Source -> Gamepad [G 0: Menu (Start)]
                        reWASD: 19:03:12:706 Mapping -> Single: (0x40 - DIK_F6)
                        reWASD: 19:03:12:706 Activator [Main ] Source -> Gamepad [G 0: Guide]
                        reWASD: 19:03:12:706 Mapping -> Single: (0x37 - DIK_MULTIPLY)
                        reWASD: 19:03:12:706 Activator [Main ] Source -> Gamepad [G 0: DpadUp]
                        reWASD: 19:03:12:706 Mapping -> Single: (0x3B - DIK_F1)
                        reWASD: 19:03:12:706 Activator [Main ] Source -> Gamepad [G 0: DpadDown]
                        reWASD: 19:03:12:706 Mapping -> Single: (0x3D - DIK_F3)
                        reWASD: 19:03:12:706 Activator [Main ] Source -> Gamepad [G 0: DpadLeft]
                        reWASD: 19:03:12:706 Mapping -> Single: (0x3E - DIK_F4)
                        reWASD: 19:03:12:707 Activator [Main ] Source -> Gamepad [G 0: DpadRight]
                        reWASD: 19:03:12:707 Mapping -> Single: (0x3C - DIK_F2)
                        reWASD: 19:03:12:707 Activator [Main ] Source -> Gamepad [G 0: LeftStickUp]
                        reWASD: 19:03:12:707 Mapping -> Single: (0x11 - DIK_W)
                        reWASD: 19:03:12:707 Activator [Main ] Source -> Gamepad [G 0: LeftStickDown]
                        reWASD: 19:03:12:707 Mapping -> Single: (0x1F - DIK_S)
                        reWASD: 19:03:12:708 Activator [Main ] Source -> Gamepad [G 0: LeftStickLeft]
                        reWASD: 19:03:12:708 Mapping -> Single: (0x1E - DIK_A)
                        reWASD: 19:03:12:708 Activator [Main ] Source -> Gamepad [G 0: LeftStickRight]
                        reWASD: 19:03:12:708 Mapping -> Single: (0x20 - DIK_D)
                        reWASD: 19:03:12:711 Activator [Main ] Source -> Gamepad [G 0: RightStickUp]
                        reWASD: 19:03:12:711 Mapping -> Single: (0xF3 - MOUSE_Y_DOWN)
                        reWASD: 19:03:12:714 Activator [Main ] Source -> Gamepad [G 0: RightStickDown]
                        reWASD: 19:03:12:714 Mapping -> Single: (0xF2 - MOUSE_Y_UP)
                        reWASD: 19:03:12:714 Activator [Main ] Source -> Gamepad [G 0: RightStickLeft]
                        reWASD: 19:03:12:714 Mapping -> Single: (0xF0 - MOUSE_X_LEFT)
                        reWASD: 19:03:12:714 Activator [Main ] Source -> Gamepad [G 0: RightStickRight]
                        reWASD: 19:03:12:714 Mapping -> Single: (0xF1 - MOUSE_X_RIGHT)
                        reWASD: 19:03:12:715 Activator [Main ] Source -> Gamepad [G 0: LeftTriggerHighZone]
                        reWASD: 19:03:12:715 Mapping -> Single: (0xF9 - MOUSE_BTN_2)
                        reWASD: 19:03:12:715 Activator [Main ] Source -> Gamepad [G 0: LeftTrigger]
                        reWASD: 19:03:12:715 Mapping -> [Unmapped] Single: (0x41 - DIK_F7)
                        reWASD: 19:03:12:715 Activator [Main ] Source -> Gamepad [G 0: RightTriggerHighZone]
                        reWASD: 19:03:12:715 Mapping -> Single: (0xF8 - MOUSE_BTN_1)
                        reWASD: 19:03:12:715 Activator [Main ] Source -> Gamepad [G 0: RightTrigger]
                        reWASD: 19:03:12:715 Mapping -> [Unmapped] Single: (0x42 - DIK_F8)
                        reWASD: 19:03:12:716
                        reWASD: 19:03:12:716 ---
                        reWASD: 19:03:12:716 "Compile Shift 1"
                        reWASD: 19:03:12:717
                        reWASD: 19:03:12:717 --- Gamepad ---
                        reWASD: 19:03:12:717 ControllerIndex: 0
                        reWASD: 19:03:12:717 ControllerType: "Xbox One"
                        reWASD: 19:03:12:717 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:12:747 Activator [Shift 1] Source -> Gamepad [G 0: A]
                        reWASD: 19:03:12:747 Mapping -> Single: (0x06 - DIK_5)
                        reWASD: 19:03:12:748 Activator [Shift 1] Source -> Gamepad [G 0: B]
                        reWASD: 19:03:12:748 Mapping -> Single: (0x09 - DIK_8)
                        reWASD: 19:03:12:748 Activator [Shift 1] Source -> Gamepad [G 0: X]
                        reWASD: 19:03:12:748 Mapping -> Single: (0x07 - DIK_6)
                        reWASD: 19:03:12:748 Activator [Shift 1] Source -> Gamepad [G 0: Y]
                        reWASD: 19:03:12:748 Mapping -> Single: (0x08 - DIK_7)
                        reWASD: 19:03:12:750
                        reWASD: 19:03:12:750 ---
                        reWASD: 19:03:12:750 "Compile Shift 2"
                        reWASD: 19:03:12:750 --- Gamepad ---
                        reWASD: 19:03:12:750 ControllerIndex: 0
                        reWASD: 19:03:12:750 ControllerType: "Xbox One"
                        reWASD: 19:03:12:750 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:12:751
                        reWASD: 19:03:12:751 ---
                        reWASD: 19:03:12:751 "Compile Shift 3"
                        reWASD: 19:03:12:751 --- Gamepad ---
                        reWASD: 19:03:12:751 ControllerIndex: 0
                        reWASD: 19:03:12:751 ControllerType: "Xbox One"
                        reWASD: 19:03:12:751 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:12:752
                        reWASD: 19:03:12:752 ---
                        reWASD: 19:03:12:752 "Compile Shift 4"
                        reWASD: 19:03:12:752 --- Gamepad ---
                        reWASD: 19:03:12:752 ControllerIndex: 0
                        reWASD: 19:03:12:752 ControllerType: "Xbox One"
                        reWASD: 19:03:12:752 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:12:774 <<<<<<<<<<<<<<<<<<<<<<<<<<<
                        reWASD: 19:03:29:187 >>>>>>>>>>>>>>>>>>>>>>>>>>>
                        reWASD: 19:03:29:187 Config path: "C:\Users\Public\Documents\reWASD\Profiles\Wor ld of Warcraft\Controller\WoW.rewasd"
                        reWASD: 19:03:29:187 reWASD version: 5.1.0.1302
                        reWASD: 19:03:29:217 ParseConfigFile return success
                        reWASD: 19:03:29:230 VirtualGamepadMapping: not exist
                        reWASD: 19:03:29:230 HideOriginalGamepad: false
                        reWASD: 19:03:29:230 ShiftModificator 1: Gamepad [XB: BtnLeftUpperPaddle]
                        reWASD: 19:03:29:230 ---
                        reWASD: 19:03:29:230 "Compile Main"
                        reWASD: 19:03:29:230 --- Gamepad ---
                        reWASD: 19:03:29:230 ControllerIndex: 0
                        reWASD: 19:03:29:230 ControllerType: "Xbox One"
                        reWASD: 19:03:29:230 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:29:231 Unmap [Main ] Unmap -> Gamepad [G 0: LeftThumb]
                        reWASD: 19:03:29:231 Unmap [Main ] Unmap -> Gamepad [G 0: RightThumb]
                        reWASD: 19:03:29:231 Unmap [Main ] Unmap -> Gamepad [G 0: LeftTrigger]
                        reWASD: 19:03:29:231 Unmap [Main ] Unmap -> Gamepad [G 0: RightTrigger]
                        reWASD: 19:03:29:232 Activator [Main ] Source -> Gamepad [G 0: A]
                        reWASD: 19:03:29:232 Mapping -> Single: (0x57 - DIK_F11)
                        reWASD: 19:03:29:232 Activator [Main ] Source -> Gamepad [G 0: B]
                        reWASD: 19:03:29:232 Mapping -> Single: (0x44 - DIK_F10)
                        reWASD: 19:03:29:232 Activator [Main ] Source -> Gamepad [G 0: X]
                        reWASD: 19:03:29:232 Mapping -> Single: (0x58 - DIK_F12)
                        reWASD: 19:03:29:232 Activator [Main ] Source -> Gamepad [G 0: Y]
                        reWASD: 19:03:29:232 Mapping -> Single: (0x43 - DIK_F9)
                        reWASD: 19:03:29:233 Activator [Main ] Source -> Gamepad [G 0: LeftShoulder]
                        reWASD: 19:03:29:233 Mapping -> Single: (0x2A - DIK_LSHIFT)
                        reWASD: 19:03:29:233 Activator [Main ] Source -> Gamepad [G 0: RightShoulder]
                        reWASD: 19:03:29:233 Mapping -> Single: (0x1D - DIK_LCONTROL)
                        reWASD: 19:03:29:233 Activator [Main ] Source -> Gamepad [G 0: View (Back)]
                        reWASD: 19:03:29:233 Mapping -> Single: (0x3F - DIK_F5)
                        reWASD: 19:03:29:233 Activator [Main ] Source -> Gamepad [G 0: Menu (Start)]
                        reWASD: 19:03:29:233 Mapping -> Single: (0x40 - DIK_F6)
                        reWASD: 19:03:29:233 Activator [Main ] Source -> Gamepad [G 0: Guide]
                        reWASD: 19:03:29:234 Mapping -> Single: (0x37 - DIK_MULTIPLY)
                        reWASD: 19:03:29:234 Activator [Main ] Source -> Gamepad [G 0: DpadUp]
                        reWASD: 19:03:29:234 Mapping -> Single: (0x3B - DIK_F1)
                        reWASD: 19:03:29:234 Activator [Main ] Source -> Gamepad [G 0: DpadDown]
                        reWASD: 19:03:29:234 Mapping -> Single: (0x3D - DIK_F3)
                        reWASD: 19:03:29:234 Activator [Main ] Source -> Gamepad [G 0: DpadLeft]
                        reWASD: 19:03:29:234 Mapping -> Single: (0x3E - DIK_F4)
                        reWASD: 19:03:29:234 Activator [Main ] Source -> Gamepad [G 0: DpadRight]
                        reWASD: 19:03:29:234 Mapping -> Single: (0x3C - DIK_F2)
                        reWASD: 19:03:29:235 Activator [Main ] Source -> Gamepad [G 0: LeftStickUp]
                        reWASD: 19:03:29:235 Mapping -> Single: (0x11 - DIK_W)
                        reWASD: 19:03:29:235 Activator [Main ] Source -> Gamepad [G 0: LeftStickDown]
                        reWASD: 19:03:29:235 Mapping -> Single: (0x1F - DIK_S)
                        reWASD: 19:03:29:235 Activator [Main ] Source -> Gamepad [G 0: LeftStickLeft]
                        reWASD: 19:03:29:235 Mapping -> Single: (0x1E - DIK_A)
                        reWASD: 19:03:29:235 Activator [Main ] Source -> Gamepad [G 0: LeftStickRight]
                        reWASD: 19:03:29:235 Mapping -> Single: (0x20 - DIK_D)
                        reWASD: 19:03:29:236 Activator [Main ] Source -> Gamepad [G 0: RightStickUp]
                        reWASD: 19:03:29:236 Mapping -> Single: (0xF3 - MOUSE_Y_DOWN)
                        reWASD: 19:03:29:236 Activator [Main ] Source -> Gamepad [G 0: RightStickDown]
                        reWASD: 19:03:29:236 Mapping -> Single: (0xF2 - MOUSE_Y_UP)
                        reWASD: 19:03:29:236 Activator [Main ] Source -> Gamepad [G 0: RightStickLeft]
                        reWASD: 19:03:29:236 Mapping -> Single: (0xF0 - MOUSE_X_LEFT)
                        reWASD: 19:03:29:236 Activator [Main ] Source -> Gamepad [G 0: RightStickRight]
                        reWASD: 19:03:29:236 Mapping -> Single: (0xF1 - MOUSE_X_RIGHT)
                        reWASD: 19:03:29:236 Activator [Main ] Source -> Gamepad [G 0: LeftTriggerHighZone]
                        reWASD: 19:03:29:236 Mapping -> Single: (0xF9 - MOUSE_BTN_2)
                        reWASD: 19:03:29:237 Activator [Main ] Source -> Gamepad [G 0: LeftTrigger]
                        reWASD: 19:03:29:237 Mapping -> [Unmapped] Single: (0x41 - DIK_F7)
                        reWASD: 19:03:29:247 Activator [Main ] Source -> Gamepad [G 0: RightTriggerHighZone]
                        reWASD: 19:03:29:247 Mapping -> Single: (0xF8 - MOUSE_BTN_1)
                        reWASD: 19:03:29:247 Activator [Main ] Source -> Gamepad [G 0: RightTrigger]
                        reWASD: 19:03:29:247 Mapping -> [Unmapped] Single: (0x42 - DIK_F8)
                        reWASD: 19:03:29:248 ---
                        reWASD: 19:03:29:248 "Compile Shift 1"
                        reWASD: 19:03:29:248 --- Gamepad ---
                        reWASD: 19:03:29:248 ControllerIndex: 0
                        reWASD: 19:03:29:248 ControllerType: "Xbox One"
                        reWASD: 19:03:29:248 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:29:248 Activator [Shift 1] Source -> Gamepad [G 0: A]
                        reWASD: 19:03:29:248 Mapping -> Single: (0x06 - DIK_5)
                        reWASD: 19:03:29:248 Activator [Shift 1] Source -> Gamepad [G 0: B]
                        reWASD: 19:03:29:248 Mapping -> Single: (0x09 - DIK_8)
                        reWASD: 19:03:29:248 Activator [Shift 1] Source -> Gamepad [G 0: X]
                        reWASD: 19:03:29:248 Mapping -> Single: (0x07 - DIK_6)
                        reWASD: 19:03:29:248 Activator [Shift 1] Source -> Gamepad [G 0: Y]
                        reWASD: 19:03:29:248 Mapping -> Single: (0x08 - DIK_7)
                        reWASD: 19:03:29:249
                        reWASD: 19:03:29:249 ---
                        reWASD: 19:03:29:249 "Compile Shift 2"
                        reWASD: 19:03:29:249 --- Gamepad ---
                        reWASD: 19:03:29:249 ControllerIndex: 0
                        reWASD: 19:03:29:249 ControllerType: "Xbox One"
                        reWASD: 19:03:29:249 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:29:250
                        reWASD: 19:03:29:250 ---
                        reWASD: 19:03:29:250 "Compile Shift 3"
                        reWASD: 19:03:29:250 --- Gamepad ---
                        reWASD: 19:03:29:250 ControllerIndex: 0
                        reWASD: 19:03:29:250 ControllerType: "Xbox One"
                        reWASD: 19:03:29:250 Id: 0x1DFF3582ED7E / 32981951638910
                        reWASD: 19:03:29:250 "Compile Shift 4"
                        reWASD: 19:03:29:253 <<<<<<<<<<<<<<<<<<<<<<<<<<<
                        • #27
                          Note that I tried the HTML gamepad tester as well and have same result as you, just that it still sends the mouse click for some reason... Even while I'm doing the test (pops up the context menu of the browser etc while I do the testing...)
                          • #28
                            Looks like this is a game problem. I attached the link to the ViewKeyCode utility. Please download and open. And follow this video steps - https://streamable.com/ap8oo. If you have the same result as video shows, then it's a game issue and needs to check the game itself.
                            In this case, specify the World of Warcraft version do you have installed?
                            • #29
                              How can it be the game?
                              If I use WoWMapper (third party controller support for World of Warcraft) I do not have the issue... Also the click happens under Windows 10.
                              This is not just an isolated issue with the game itself.
                              • #30
                                I'm using the utility and it also detects raw mouse input where left trigger sends a RIGHT_BUTTON_DOWN and right trigger LEFT_BUTTON_DOWN additionally to the F7 and F8
