Xbox Elite Wireless Controller Series 2
  • #31
    Message Key name (internal table by scanCode+flags.LLKHF_EXTENDED) VKey MakeCode Flags ExtraInformation Reserved GetKeyNameText(MakeCode+RI_KEY_E0) hDevice
    WM_KEYDOWN F7 0x76 VK_F7 0x0041 0x0000 0x00000000 0x0000 F7 0x00010047
    WM_KEYDOWN F8 0x77 VK_F8 0x0042 0x0000 0x00000000 0x0000 F8 0x00010047
    usButtonFlags usButtonData ulRawButtons usFlags lLastY lLastX ulExtraInformation hDevice
    0x0004 RIGHT_BUTTON_DOWN 0x0000 0x00000000 0x0000 0 0 0x00000000 0x0001003B
    0x0001 LEFT_BUTTON_DOWN 0x0000 0x00000000 0x0000 0 0 0x00000000 0x0001003B
    0x0001 LEFT_BUTTON_DOWN 0x0000 0x00000000 0x0000 0 0 0x00000000 0x00010039
    It seems that the controller has 2 hDevice, is that possible?
    0x00010047 and 0x0001003B... (0x00010039 is my mouse)
    • #32
      Sent you a private message, please look at messages tab.
      • #33
        OK found my issue, for anyone having a similar problem in the future, it might be that you've downloaded one of the config from the website that had the triggers bound to mouse clicks, which for some reason I could not find and disable in reWASD.
        Eventually what solved the issue was just wiping all the configs, creating a new blank config and just setting it up manually as I should have done originally...
        Should have done that from the beginning haha... Oh well, now all is good!
        • #34
          Thanks for the update. In my case I only really at this stage want to restore the Gamepads functionality because I cannot use the Xbox app. However in Jedi fallen order it appears to be ignoring my remappings in REwasd. Is there still a problem using the Xbox wireless connector?
          • #35
            Please check the physical Slot you are using now and Xbox app settings.
            There are two possible solutions:
            1. Switch to the physical Slot 0 (you won't see any lights on the controller's slot switcher in this case)
            2. Go to Xbox app and create a new empty profile in which paddles are Unmapped. Save it to all the slots.
            Then, please re-apply reWASD config and try again.
            • #36
              Thanks for that I worked it out to just not use the profiles before I saw these posts but now I have a new problem, whenever I try to reconnect the controller I get this error. (screen attached.)
              • #37
                May I ask you to send us msinfo of your Windows OS. Press win+r - >type msinfo32 - > safe the file.
                • #38
                  Hi star-Lord. Tried to send this but it's over 3 meg and the forum won't let me upload.
                  • #39
                    Please send the msinfo official support center this address support-eml@disc-soft.com
                    Thank you.
