Should the Xbox Elite Wireless Controller Series 2 be supported? I know it just came out, but maybe it's so similar to its predecessor that it's automatically supported?
I bought REWASD yesterday to be used with this controller. At first it seemed to be working fine but then the back paddles disappeared from the configuration interface in REWASD and I tried everything to get it back to the way it was before, but couldn't.
Any help? Thank you
Any help? Thank you
