Problem with the "Remove applied config from slot on exit from the associated app" Setting.
I like this setting a lot because when I exit a game it automatically remove remapping on my mouse. Remapping that can interfere with the likes of Chrome etc.
The problem is that it also remove mapping when I minimize the game for a short little while. reWASD should check if the process is still running before unloading the config.
