Thank you for the video. Can you send your config as a file? Your configs are stored here: C: \ Users \ Public \ Documents \ reWASD \ Profiles I need the correspondent * .rewasd file.
Mouselook Locked While Move
I attached the rewasd configuration fileOriginally Posted by 1ncorrect View PostTo test your problem, I need a config. Can you send it?
Disregard the last post. This is the right configuration file GW2.rewasdOriginally Posted by 1ncorrect View PostTo test your problem, I need a config. Can you send it?
Strange, just tested your config in a similar MMORPG. I can't play the sharp jump of the mouse like in your video. Perhaps your MMORPG has a checkbox in the settings that makes the mouse jump to a certain point when you right-click. (I had such a checkbox in MMORPG, and usually I removed it)
No. This is GW2 and the only key to jump is spacebar. This agressive rotation happen in WoW too. In WoW has the same simple key for jump, the spacebar.Originally Posted by 1ncorrect View PostStrange, just tested your config in a similar MMORPG. I can't play the sharp jump of the mouse like in your video. Perhaps your MMORPG has a checkbox in the settings that makes the mouse jump to a certain point when you right-click. (I had such a checkbox in MMORPG, and usually I removed it)
I see.Originally Posted by 1ncorrect View PostYou misunderstood me, this is not a jump button. And in the setting of the game, in which pressing RMB makes the mouse to jump, as in your video. As I said, the config you sent works fine for me.
I looked into the game control and mouse settings and I can't tell what setting is messing with the cursor.
Two MMOs with same exact problem? I dont think so.Originally Posted by 1ncorrect View PostPerhaps clearing the data will help you. To do this, go to Preferences> General> Clear data button. Restart reWASD and apply your config again. If this does not help, most likely the problem is in the game itself.
From the side of reWASD and the config itself - everything works well.
