Weird problem on Ps3 navigation controller
  • #16
    Thank you for your attempt to try on another PC. Any chances to test another BT adapter?
    • #17
      I tried 3 different Usb dongles. in a different pc and the bug continues. but only via bluetooth.
      • #18
        Hi there,
        I see. We will try to investigate the case in detail and let you know the result.
        Our apologies for the inconvenience.
        • #19
          ok thanks for all. this software its perfect just that little thing. I'll be waiting for the fix. Thanks again.
