Suggestions for Gyroscope Activators (and other things)
  • #16
    Unless I am missing something. Can I not just map the Gyro to kick in with pulling the trigger to its full extent. I would also like this to be used as a shift "trigger" I would love to use this over Steam but Steam has Gyro implementation nailed. Overlays, radials and buttons mapped to touch pads (Steam pad and DS4) would be great too.
    • #17
      Hello! You can switch Gyro only when the trigger is pressed. You need to map Gyro inside Shift mode and set a trigger as a modifier. Please learn more here.
      • #18
        Great, thanks!
        • #19
          I'm trying to get this suggestion to work, but only the opposite of the desire behavior works. There should be a separate on and off mode, as what happens is that the gyro is left enabled, and as soon as I touch the touchpad it gets disabled, and as I remove my thumb it gets enabled again. So the opposite of what I want. Any ideas of how to get this to work in the correct order?
          • #20
            Answered here.
            • #21
              None of the your answers works though. The touchpad can't be enabled as a shift activator, and the start press and release press do the opposite, as I described above.
              • #22
                reWASDer, any news concerning flick stick?
                • #23
                  Hello.
                  We have it in the plans, but it's hard to talk about approximate dates yet. Stay Tuned!
                  • #24
                    Both Trackball mode and Flick Stick are already implemented!
                    Please check our latest reWASD 6.2.1.
