ChillBear I would guess you can help get the configurations right.
Lost Ark reWASD movement + autoaim
If this worked initially, then something in your config may have been accidentally changed.
Try to recreate the config from scratch, or make sure that all mappings are in accordance with this guide.
If everything is set up correctly, but the mouse still does not work, please send us your configuration file.
I need the corresponding *.rewasd file.​
So I got it working, i had to change left and right click in the game settings, forgot chillbear had them swapped. But now im working on changing the keybinds around. I use 1-4 then QERF. It feel like it should be more simple than it is with this program lol.Originally Posted by 1ncorrect View Post
Unfortunately, Lost Ark doesn't offer much in the way of WASD so the workaround is complicated. They could make some very small changes which would make WASD much easier to make with reWASD and more fluid. Hope you can figure it out with the guide!Originally Posted by CookieChee View Post
I did try with WASD a couple months ago and it was still working well with the guide
I tried config post by ChillBear, everything work ok except Targeted AOE skill. When I press the skill, the target circle is under the character's feet, I can't use mouse to move it, and I press LMB, it doesn't activate the skill.Originally Posted by strokel View PostGlad to know.
Should you have any other questions or require further assistance, please let us know.​
Hi JohnWang
Please try to check if the mapping works correctly and if there is a similar behavior in the tester:
Using Chillbear's "Sorceress PVE" config, (I'm playing Sharpshooter) I've been using WASD and Mouse Aim with no issue , save 1. I can not for the life of me figure out how to get the Mouse Aion + skill to interrupt my movement in the opposite direction.
For example: I'm running left, and Mouse is to the right on the boss. If I hold A, the skill goes off in the direction I'm looking. If I let go of A just prior to using skill, no issues, goes to mouse aim. For Snipe skill specifically, if I'm holding a directional button, the cursor goes to my feet. If not holding, it acts normally.
Is there something I'm missing, or is this just not currently possible b/c of how Lost Ark works?
The forum isn't allowing me to edit post, some type of error.Originally Posted by Arrouu View Post~~Using Chillbear's "Sorceress PVE" config, (I'm playing Sharpshooter) I've been using WASD and Mouse Aim with no issue , save 1. I can not for the life of me figure out how to get the Mouse Aion + skill to interrupt my movement in the opposite direction.
Is there something I'm missing, or is this just not currently possible b/c of how Lost Ark works?~~
I solved the above issue, was user error. Using Chillbear's Sorc config as a foundation, was able to get all the Sharpshooter skills to "work". I'm wondering how I can get them to work off release though? Presently my work around is a delay inside his "F" macro, effectively allowing me to fire off Snipe with 1300ms delay and Charged Shot with 1000ms, which gives it time to charge to the success zone. Would love to press, and then release when I want ,would help with Charged Shot too, because the charge effects distance but not dmg. I'll continue to dig around, I'll post what I find here, for whatever it's worth, along with the config.
